Hey guys i need help pls when i start game it runs fine and after sometime playng it drops to 30-40 fps idk why if somone can help pls
It happens il all games
help me please its hapenning 2 months straight
idk why i taked my pc at servis and they reinstalled the windows and cleaned it and changed termal paste idk why it hapends
https://linustechtips.com/topic/1411623-guys-please-help-me/
10 hours ago, CiciLedzi said:
It was today and my specs are r7 240 gpu amd athlon x4 840 quad core 3.10 ghz and 8 gb ram.
And 1tb hdd
Could be overheating. What games are you playing? When have you last cleaned the PC?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1411623-guys-please-help-me/#findComment-15260599
32 minutes ago, CiciLedzi said:
I cleaned it and changed termal paste and same thing is happening.
Ok, next reason would be something else eating CPU on the background. Your system is fairly old in modern standards, so if you are playing demanding games, any thing happening in the background will have big impact.
https://linustechtips.com/topic/1411623-guys-please-help-me/#findComment-15261159
i turn of all programs and same
https://linustechtips.com/topic/1411623-guys-please-help-me/#findComment-15261175
the problem is only you could possibly figure this out, sure we can point in the right direction, but just "guys help" isnt going to actually help much.
So you need to check:
cpu usage *per core*
ram usage
gpu usage
vram usage
while playing, and then you need to check whats exactly happening when your issues show up.Use afterburner , post screenshots if you're unsure about interpreting the data.
Should look something like this (afterburner monitoring) of course there are a lot more data points, as Ive mentioned above.
Otherwise we're just guessing here and you said it worked well before, so something obviously would  have had to have changed, thats what monitoring tools are for.
-Scott Manley, 2021
https://linustechtips.com/topic/1411623-guys-please-help-me/#findComment-15261233
