Speeds in upstairs office much slower using Powerline adapter
17 minutes ago, steelo said:Hi everyone,
聽
I apologize if this seems to be a dumb question...I love building PC's and writing code, however networking is not one of my strong points聽
聽
I have a TP-Link Archer AX1800 router downstairs running ethernet cable to a Netgear powerline PL1000 adapter plugged into a wall socket. Upstairs I have another PL1000 adapter that is wired to an older Netgear Nighthawk router running as a switch (and wifi repeater for mobile devices). From there my PC is connected to the network switch (Nighthawk router) via ethernet cable. My question is, I am getting around a 400-500 mbps internet connection downstairs. However, upstairs I am only achieving 50-60 mbps. Is this normal or could the switch acting as an intermediary be causing this issue? I am wondering about the benefits of updating the firmware on the Netgear Nighthawk and whether it will make a difference if it is only a simple network switch.
聽
Thanks everyone!
聽
Power line adapters are hit or miss on speed. They are dependent on quality of wiring and other factors. The speeds advertised are the speed between the adapters. Many only have 100Mbps Ethernet ports therefore only get a max of 100Mbps. There are so many ways power line 聽adapters can be interfered with.聽
