Okay, so I used to have a 75 hz monitor right now I have a 60hz 4k one and windows says it can only go up to 30hz and my gpu (rx 550 bad I know) It can handle 144hz at 4k  I believe and the hdmi is through the gpu can someone help I have all my drivers up to date and everything.
https://linustechtips.com/topic/1409822-help-confused/
Over HDMI, you need 2.1 for 4K@120Hz and HDMI 2.0 for 4K@60Hz. The RX550 should support 2.0, but it's possible the monitor may only be 1.4, or perhaps the particular card only has a 1.4 port for some reason. Anyways, that's the most likely reason you'd be limited to 30Hz. You should use DP instead, if you have the option.
It could also be a cable issue. The cable needs to be capable of carrying the signal you're trying to send through it. If both the GPU and monitor support HDMI 2.0, you probably have some jank cable that can only support 1.4.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1409822-help-confused/#findComment-15247360
3 things has to be right.
the cable
GPU supported port like DP or HDMI
the monitor or TV's port, DP or HDMI supporting it too.
Also sometimes it might be set at a higher bit color, turning it down could help. from 10 bit to 8 bit or something like that and what is supported.
https://linustechtips.com/topic/1409822-help-confused/#findComment-15247367
I just bought an ultra speed 2.1 cable lol
https://linustechtips.com/topic/1409822-help-confused/#findComment-15247370
17 minutes ago, sebaydawebay said:
U32J59
You have two HDMI port on your monitor. 1.4 and 2.0.
Make sure you're connected in the HDMI 2.0 port of the monitor.
https://linustechtips.com/topic/1409822-help-confused/#findComment-15247483
10 minutes ago, sebaydawebay said:
DUDE, THANK YOU SO MUCH IT WORKS!!!
And that's why you should always read the instructions. Even if it looks "obvious". 😂
https://linustechtips.com/topic/1409822-help-confused/#findComment-15247519
22 hours ago, IPD said:
nothing for that in 30" comes up on google.
The reason it matters, is because monitors can often have multiple inputs, but not all are at the same spec.  My AOC has a HDMI 1.4 and HDMI 2.0 input.
Same thing with mine.  I figured it would an easy fix.
https://linustechtips.com/topic/1409822-help-confused/#findComment-15249048
