Ill start
GPU: Asus Direct CU 1gb HD7850
Idle temp in my case: 25 degrees C (browsing web for 10 min)
Load Temp: 63 degrees C (Bf4 for one hour max temp, on gaming preset in GPU tweak, so slight OC)
https://linustechtips.com/topic/140734-post-your-gpu-temps/
EVGA Reference 780
Idle: 24C
Load: 45C
WOW Lol thats nvidea beats AMD
Mine is a low quality card, aftermarket cooler, and 7 case fans
Yours is high quality card, refferance design, and not sure about fans
Yours is 1 degree cooler...
Nope NVM water cooling
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878646
Since I still haven't replaced the board's crappy heatsink... about 75C with great airflow... In a not-so-demanding game...
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878650
Maybe I should have added it's watercooled lol
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878668
oh. Ok now i dont feel so bad about my card. You said refferance so i thought
Not
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878686
What are you guys using for stress testing?
Unigine Valley? Game? etc...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878712
MSI GTX 760 mini
Idle temp:  37
load temp: 85
That's the power of the Lian-Li PC-TU100B
Available from 3pm to Midnight Eastern Time (GMT-5). (>'-')> <('-'<) ^(' - ')^ <('-'<) (>'-')> You can't stop the kirby dance.
4770k | Gigabyte GTX 970 Mini | Lian Li PC-TU100B | MSI Z87I 2x8GB G.Skill Sniper | Noctua NH-L9i Silverstone Strider 450W SFX | Windows 10 | 2x 250GB 840 Evo Rad 0 1x 1TB WD 2.5" | 25% gaming, 25% CAD and rendering, and 50% web browsing.
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878717
Just to clear somthing up, my temp is not actualy idle. I have been browsing the web for 10 min and it is still at 25c
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878731
Hey if a mod could move this I guess I accidentaly posted this in CPU, ment for gpu
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878769
Inno3D GTX 660
Idle: 27C
Load: 72-76C
Can't push any further without crashing
Intel Core i5 3570K@4.5GHz | ASRock Z77 Extreme4 | 2*TEAM 8GB DDR3-1600@CL9-9-9-27 | Inno3D GTX 660 HerculeZ 2000s@1200MHz Core 6600MHz Memory | Seagate Barracuda 2TB | Antec Kühler H2O 620 | Antec HCG-620 | CoolerMaster Elite 371
Acer Iconia W700: Intel Core i5 3337U | 4GB DDR3 | 120GB SSD | 11.6" 1080p Display
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1878822
EVGA ACX GTX 770 2gb
idle:26 ish
Load:72
Using BF4 ultra preset
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1879107
GTX 780 1200MHz core @ 1.212V 24\7 settings
Room temp 24C
Idle 35C
Max 76C     (2 Passes of Unigine Valley Extreme HD)
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1879306
Idle for my evga 780ti sc with the acx cooler on it is right around 31c with my room temp around 23-24c. My current temp is 41c but I am watching tv through my tv tuner card on one monitor, web browsing on another and the other one just has several folders open on it at the moment. warmest i have seen it was about 58c after 3 hrs of gaming on far cry 3 on my 1440p monitor. I think when it gets warmer in the summer and my room temp gets closer to 28c  it will top out over 65c.
"Science and technology revolutionize our lives, but memory, tradition and myth frame our response."
Arthur M. Schlesinger
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1879501
Sapphire dual-x r9 270x
Idle: 31
Max load: 60-70
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1879658
Crysis 3 maxed 1080p 72c 40% fan r9 290.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1880737
Sapphire R9 270X Vapor-X.
Idle: 30-35 degrees.
Load: 70-74 degrees.
Not that my ambient temperature is usually higher than in NA. So idle temps may be lower for someone else. Also, the cooling system seem to be set to keep the card below 75-76 degrees. Its very quiet this way and only ramps up and becomes clearly.audible if I'm mining.
https://linustechtips.com/topic/140734-post-your-gpu-temps/#findComment-1880809
