GPU fans running wild
you wouldn't happen to have a powered USB hub on the system right? I ran into this obscure case a few years back where a cheap hub was back-feeding power into the motherboard's USB which shared grounds with various components (super weird but unplug the hub and my GPU fans ramped down to normal, plug in and max speed)
based on the temps a repaste shouldn't be needed, based on CPUID the card isn't sending rpm reading to the programs so I would try setting it higher to 50% and see if the fans react then walk it down to where it won't go any lower or starts to ramp back up (safety in the card's firmware when not enough amperage is sent to the fan to start them spinning causing it to default or go full speed to protect the components from a fan rpm signal loss) That card is on the edge of the "stop fans" generations which allowed zero rpm and gave the fans a kick to start spinning before going to the setting in the OS.
I would also uncheck "use firmware control mode" and "enable user defined software control" and restart the machine to see if it's software talking to hardware or firmware talking to hardware. basically remove the layers of control until the fans act normally and reintroduce the controls one by one to narrow the possibilities.
