QUESTION: Will RAM with different Megahertz, capacity, or brand work together on the same motherboard?
Solved by Sprawlie,
yes. (with caveats) you can mix and match ram like that. However, the RAM that doesn’t match will only run single channel, and all timings/speeds will run at the slowest of the set (eg, if you have 3 sticks that are 3600mhz, but one that’s 2133, All will run at 2133)
Also Caveat: Sometimes it just doesn’t work. I have encoutered a few boards, and servers over the year that will not post with some weird combinations. But generally speaking. You do not have to use matching sets.
Just generally speaking not worth the performance losses.
