We need to know what mouse you have.
Is "lift-off distance" a setting you can adjust in the mouse's software?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1402326-mouse-problem/#findComment-15196016
22 hours ago, Aree Soothsayer said:
Wtf. The screen... but it's going to be covered by my... Why would...
OK, staying on topic. You need to look for a setting in the mouse software (I assume it has some to control the lighting and such) for "lift-off distance." If there is no such setting, I'm afraid I can only advise buying a better, less gimmicky mouse.
https://linustechtips.com/topic/1402326-mouse-problem/#findComment-15197434
