Help me find a good Wifi connector please?
zcailz
Hi, I just started looking at wifi cards for my computer and I have no idea if i should take a pci card a m.2 card or a usb stick what would be best and wich one should I choose? Thanks!
That depends a lot on the connections your motherboard has. I am a big fan of this product, but it does take up a PCIe slot, also the Bluetooth only works if you run an internal USB cable (due to the way M.2 cards works)
https://www.gigabyte.com/Motherboard/GC-WBAX200-rev-10#kf
If you have a correctly keyed M.2 slot, then that might be cleaner, but the slot MUST be an A or E keyed slot (which allows for USB connectivity for bluetooth). Storage M.2 slots are typically B+M keyed and will not work for WiFI cards.
I hate USB for things like this and avoid whenever possible.
thanks!
14 minutes ago, zcailz said:
thanks!
Really sorry but it looks like I recommended a discontinued product. Here are two cards you can buy that still use an Intel chipset. These are both from no-name companies, but keep in mind that it is the Intel chip you are getting, the card itself it basically just a PCIe to M.2 adaptor. Most of the name brand cards use broadcom chipsets, which work, but most people will tell you Intel is the gold standard. With these cards, you just need to install the Intel drivers, no need to install anything from these company's webpage.
https://www.newegg.com/fenvi-fv-axe3000-pci-express/p/0XM-00JK-000A1?Item=9SIADXZE416894&Description=AX210 card&cm_re=AX210_card-_-9SIADXZE416894-_-Product&cm_sp=SP-_-489007-_-0-_-6-_-9SIADXZE416894-_-AX210 card-_-ax210-_-3
https://www.newegg.com/teday-td-ax210-pci-express/p/0XM-01CY-00041?Description=AX210 card&cm_re=AX210_card-_-0XM-01CY-00041-_-Product&quicklink=true
Nice to see AX210 PCIe cards finally show up.  Last I checked they were all AX200 but in my experience the AX210 performs a fair bit better even on WiFi 5/AC networks.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Yeah, performance on of the AX200 card wasn't all that impressive. I mean, 600-700mbps over WiFi is pretty nice, but falls far short of what WiFi 6 should have been able to deliver (I typically expect about 50% of the theoretical limit from WiFi, what I saw was more like 25%). I haven't tested AX210 yet, but I would be interested to see if it works better on WiFi 6 networks or if it only shows improvements on 6E.
I did get 940Mbit once on the AX210, but there's something a bit odd about 5Ghz in my room as I seem to average somewhere between 400-800Mbit even though the Access Point is on the ceiling with direct line-of-sight.  Tried several different Access Points and they all behave the same, the speed seems completely random.
I also seem to get better real-world performance copying over Samba shares than iperf3 would suggest.
