Proper SSD and mounting solution - Help needed
Solved by AbydosOne,
2 minutes ago, TubbusMaximus said:
It's a reasonable choice. Honestly, I wouldn't have steered you away from a PCIe 4.0 drive as it will probably outlast the motherboard and could go in your next build (but by then, PCIe 5.0 will be a thing, so
