6 minutes ago, RONOTHAN## said:
What PSU specifically. There are some 80+ gold PSUs that are amazing, and some that aren't worth the sheet metal they're made out of. 600W is a bit low for a 3070Ti rig, but it should work (probably) if the PSU is pretty good.
it’s a thermaltake smart series
https://linustechtips.com/topic/1398740-power-to-my-gpu/#findComment-15172508
10 minutes ago, oliverbarca said:
So i got a rtx 3070 ti, but my PSU is 600w 80+ gold. It’s also non modular and i think it only has a daisy chain PCIe cable. PC part checker says my system only runs 498 W, but i was wondering if this set up would be fine.
You’re cutting it close, but it should work. A single cable is a little worrisome, but if it’s a good quality PSU it will use thick enough gauge cable where it will be totally fine.
https://linustechtips.com/topic/1398740-power-to-my-gpu/#findComment-15172510
2 minutes ago, oliverbarca said:
would there be some problems if i kept it as is?
Yes. The Thermaltake Smart series at that low of a wattage isn't known for being good. It's not one that will blow up (AFAIK), but it's a PSU that should be avoided if you plan on using a GPU.
Get a better PSU. the RM750x would be a better option
https://linustechtips.com/topic/1398740-power-to-my-gpu/#findComment-15172526
I'm guessing you're referring to the SMART Gold/SMART BM2? I still wouldn't go for it with a 3070 Ti but it's a fine PSU for lower power draw systems. Strictly speaking it'll work but I would not call it ideal.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1398740-power-to-my-gpu/#findComment-15172533
5 minutes ago, oliverbarca said:
Is replacing a PSU hard? my cousin built me my pc so i don’t know.
You just have to unplug all the cables, unscrew the PSU and redo all the cables. The tricky part is managing all the cables in the PC; they all look different and go to vastly different places so it's not hard to get it to work. The challenge is getting it to look nice.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1398740-power-to-my-gpu/#findComment-15172663
