Meed help choosing a budget gigabit switch
16 hours ago, Blue4130 said:Metal housing doesn't mean it runs cooler, unless the ic's are actually in contact with the housing. The amount of passive cooling is next to zero.
21 hours ago, Sir Asvald said:What is your budget? Plastic or metal, as long as the switch is working, who cares?
While you are correct that plastic has no direct influence.
In my experience with at least 100 switches, the one where that manufacterer put the effort to make it metal, last way longer.
And as most are possible made in the same factory, its good trusted tech.
22 hours ago, Sir Asvald said:You get 3 extra ports for 1 euro more.
Personally if i did not need the ports i would not go for that model.
Unknown brand, does not have to keep its name in high regard.
Looks cheaply made, so my guess the internals arent much better either.
The specs clearly show the shortcomings of the plastic 8 port. Half the buffer.
Less compatibility, and mostly no mention of MTBF
As where the 5port shows at least 60000 hours... And less powerusage.
Going for that 8 port, i can assure you it can only give headaches....
I've been there. It's not worth anyone's time.
