Asus Strix z690 motherboard. 2x8 pin power connector requirement
Solved by _Kaurus,
2 hours ago, -rascal- said:
One CPU 8-pin should be enough / is only required.
The second 8-pin connector is only needed if you:
- Have a REALLY power hungry CPU or,
- Doing some next level CPU overclocking
A single 8-pin EPS connector can supply up to 384W to the CPU.
Using 2x 8-pin EPS = 768W.
If your CPU alone pulls 768W...then dear god....
Corsair HX? 850W should have 2x connectors.
2x 4+4 connections.
Again, you shouldn't need to use all two...
Thanks!
If the PSU labeling was clear, I'd not have to ask these questions. It literally says "6+2 PCI-E & 4+4 CPU".
LINK. I think what they are trying to say is use these two cables for either PCI-E or CPU..
