Hard Drive Shucking
Go to solution Solved by AbydosOne,
11 minutes ago, RJ45-Dude said:
Does it work with any kind of external hard drive (for example, this is my hard drive: https://amzn.to/3og7Zv2), or does it have to be specifically larger external hard drives (for example: https://amzn.to/3I8DYFA)?
Some (not necessarily all) 2.5" portable HDDs have the USB port integrated right into the PCB, so there's no standard SATA to connect to. Also, generally, the price to capacity just isn't there to warrant it. Usually the 3.5" (larger) drives are where the incentive to shuck comes in. (Even then, IIRC the 6TB WDs are SMR Blues internally; would recommend 8TB and up for CMR higher-performance drives).
12 minutes ago, RJ45-Dude said:
Also, when watching tutorials on how to shuck hard drives, I learned that there is a pin on the hard drive itself you must cover up, as this pin controls the hard drive's power. However, in the tutorial, the hard drive had a button, while my hard drive (listed above) does not. Do I still have to cover up that pin?
This is the PWDIS pin, which is technically part of the newest ATX power standard. It uses the 3.3V rail pulled low to start the drive spinning. The downside being that most (all?) PSUs out there today still provide 3.3V over SATA power, and hence will hold the drive spun-down if it isn't fixed. Furthermore, this feature's presence varies from model to model and even drive to drive inside a specific model (call them sub-models). The safest way is to just make sure you don't feed 3.3V to and drive by either taping over the pins or removing the wire from the connector (if it happens to be one of the modular ones), but it isn't always strictly necessary.
In regards to this button: I'm not aware of any internal HDDs that have any form of user interface like that. They're all just plug and go as far as I'm aware.
Bonus tidbit: the PWDIS actually has a use in server-space (where a lot of the excess drives funneled into the external market come from), so that the system can stagger the spin-up of all the drives in the case of a 24 drive disk shelf, etc., and not overload the PSU.
Hi, kinda newbie to the tech world here. I had two questions about hard-drive shucking...
Thanks to anyone who helps.
https://linustechtips.com/topic/1392767-hard-drive-shucking/
It should work as long as there's a 3.5 inch drive in there. There appears to be one in there, so it should work. The main reason people do it on higher capacity drives is that on these lower end ones, it doesn't make financial sense to do it - you lose a warranty, have extra work, and generally aren't saving much, if any money doing this.
https://linustechtips.com/topic/1392767-hard-drive-shucking/#findComment-15133276
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1392767-hard-drive-shucking/#findComment-15133278
2 minutes ago, RONOTHAN## said:
you lose a warranty
Fun fact: you don't lose the warrantee when you shuck. Just threaten the manufacturer with the Magnuson–Moss Warranty Act and reporting them to the FTC and they'll generally comply.
You'll almost always save money doing this for larger drives: WD Easystore 14TB = (currently) $250; WD Gold 14TB (basically the same drive) $385.
Network:
https://linustechtips.com/topic/1392767-hard-drive-shucking/#findComment-15133280
Yeah, I was implying that with the lower capacity drives (~4TB or less). Probably could've clarified a little better. Big drives is where you should consider doing this.
Interesting to know about the warranty claims though.
https://linustechtips.com/topic/1392767-hard-drive-shucking/#findComment-15133284
This assumes that one is in the usa. That doesn't work for other countries.
https://linustechtips.com/topic/1392767-hard-drive-shucking/#findComment-15133428
