MSI Afterburner Fan speed % doesn't match others
As said in the title the fan speed % in msi afterburner doesn't match the others like Aida64. Is it because the two fans are on seperate connectors inside the gpu and aida reports incorrectly?
Because by mathematics
If,
Fan Speed Highest=2850rpm
and Current=1720rpm
So Approx 40% comes out which means Afterburner and hwinfo percentage is nearer to the current % reported (Rpm is same in all apps).
So what is this issue? Because in my previous 1660s dual fan this issue was not present (it had both fans on a single connector).
  • AMD Ryzen 7 5700X Undervolted  with PBO+Eco Mode
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600 8GB GDDR6
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
It seems Aida is just picking up percentage wrong, probably because it has an incorrect max RPM. Afterburner and HWInfo both agree on the % so I'd trust those.
Also since there are two seperate fangs so I think the percentage is wrong. Anyways custom fan curves through msi afterburner should be safe I guess.
The card is a MSI Mech 2x 6600 OC 8G
  • Deepcool AK620 WH
  • Deepcool CK500 WH
