CPU Temps
Go to solution Solved by Levent,
As long as temperatures are below tjmax (IIRC 105c for intel and 95c for AM4 cpus) its fine, dont bother.
Hi, I've just put a new PC together (see signature) and my CPU temps seem to vary a lot.  Is this characteristic of everything settling in, like the pre-applied thermal paste on the CPU block? It's been 9 years since my last build so I'm unfamiliar.
I can see they've become a bit more consistent but is still moving ±10°C each second. Is it worth putting some fresh MX-4 on and remounting? The case has been a struggle to say the least so I'm reluctant to do any more work if it can be avoided.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/1388594-cpu-temps/
https://linustechtips.com/topic/1388594-cpu-temps/#findComment-15103276
Fair enough, thanks!
https://linustechtips.com/topic/1388594-cpu-temps/#findComment-15103584
