gigabyte rtx 2080 low clock speeds and voltage
flowerbunny
furmark.thumb.png.e619452222d4343e093526c1faa1608a.pnghi
I have have a rtx 2080 gigabyte gaming oc 8g gpu it worked fine for over 2,5 years until the summer it started to overheat and throttle.
So since i didnt have warranty anymore i opened it and replaced thermal paste and pads it ran fine afterwards for 4 months with good thermals of about 65 degrees.
Since a couple of days ago it i noticed it doesn't boost anymore it stayed at best around 1600 - 1700 mhz i also noticed it only pulled around 90 watts and 0,8 volts temps also dont go above 50 degrees.
Also overclocking doesnt seem to work anymore not matter what i do the gpu just keeps going at the same speeds and voltages.
I flashed the bios, uninstalled (ddu) and reinstalled the drivers, reseated it, i checked my power supply by putting the cables in different connectors, deleted my oc and ran it at default but nothing seems to work.
my specs:
RTX 2080 gigabyte gaming oc 8g
Z390 aorus pro wifi motherboard
i7-9700k cpu
corsair hx1000 psu
Corsair 32 GB DDR4-3000 ram
ill add more info if necerssary.
what about other onboard sensors? Hwinfo64 in sensor mode can read them
Desktop benching:
ill add those when im running furmark and ill post a screen shot
i just found out that my nzxt cam software was acting up so i uninstalled it when i adjusted the settings in the cam software my card woul overclock and it would behave differently so i uninstalled it but i msi afterburner still wont overclock
alright nzxt cam just overrode everything and just made my core clock drop its solved now can anyone tell me how i can close this topic ?
