GPU is not in BIOS, so how to i set fan curve after GPU temps?
MatsNorway
Is there any way to run the fans or some of the fans by GPU temp rather than CPU temp? Software or hardware, anything goes.
You should give this a try! I personally use it and it works fantastic.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Can confirm that it works wonders (I am doing exactly what OP is asking)
