Does Type-C DisplayPort™ work on a Thunderbolt 3 cable?
A Thunderbolt 3 cable is electrically compatible with a USB-C cable, they use exactly the same connectors and wiring. The TB cables have better shielding and usually thicker wire gauge on the power lines to provide charging current, which is why they're more expensive and labeled that way so consumers don't buy a cheap cable when they need TB 3 support.
So you can use a TB 3 cable for a standard USB-C connection, TB 3 is just a protocol built on the USB-C standard. Much like you can have 100 Mbit/s, 1 Gb/s, 2.5 Gb/s or 10 Gb/s ethernet all using the same RJ45 port, but if you want to go for higher speeds, you need cable that has the proper wire gauge and shielding, a Cat 5 cable won't do 10 Gb/s, but a Cat 8 cable will always be compatible with 100 Mbit/s
