I am upgrading my house to 10 gigabit connections (because i feel like it) on my computers and learning on the fly.
I have bought everything off eBay and amazon but now realize i may have a problem... or not i dono stuff is still in the mail
CISCO WS-C2960S-48LPS-L CATALYST 48 PORT PoE+ SWITCH
Intel EXPX9501AFXSR 10GbE XF SR Server Adapter x2
10GBase-SR SFP+ Transceiver, 10G 850nm MMF x2
So the NIC and SPF are SR which i didn't notice till this morning will those work with the switch?
Also i didn't know there was a difference in cables (SR and LR) so i grabbed 1x 3ft multi mode cable for the switch to the NAS but i grabbed a 50ft single mode cable for the switch to my main computer. Do i need to get a multi mode cable to replace the 50ft one or will a single mode cable work in a multi mode connection?
https://linustechtips.com/topic/1383795-fiber-cable-question/
Id personally run it all single mode.
Thats xr not sfp+, you probably don't want it, id getting something like a x520 or connect x3 instead
Id get the lr transcievers and go all singlemode
Id probalby go mikrotik or other newer switches. This is gonna be loud and power hungry.
https://linustechtips.com/topic/1383795-fiber-cable-question/#findComment-15066318
but the NIC is 10G why is XR bad vs SPF+
the switch will be in the garage and I have free electricity so that doesn't matter.
Also i already bought this stuff (its in the mail currently) and while i can just but them back on eBay to sell, i don't see the need unless something literally will not work. which is what i was asking originally.
https://linustechtips.com/topic/1383795-fiber-cable-question/#findComment-15066330
There are lots of 10g standards.
XR is a different connector than SFP+, so your transcievers won't work. Its also a old eol standard, so finding parts will be harder, and software support is probably gone for the nic too.
https://linustechtips.com/topic/1383795-fiber-cable-question/#findComment-15066332
Ok that is what i was wondering thanks.
can you recommend a card that'll work with freeNAS or TureNAS? Also i'm looking for cheap hence the eBay searching
https://linustechtips.com/topic/1383795-fiber-cable-question/#findComment-15066343
Look at those nics I suggested earlier? Connect x3, x520. For other cards, id google to see wht peopls experience with them on freebsd is.
https://linustechtips.com/topic/1383795-fiber-cable-question/#findComment-15066353
The switch doesn't have 10gbps ports.  It has 4 SFP ports, capable of maximum 1 gbps.
So it's kinda pointless ... I mean you can still use it for the 48 x 1 gbps ports but why waste a couple hundred watts for a gigabit switch. You could just get a basic non-management switch if you want that.
I'd suggest getting a microtik 5 port 10g switch with 4 sfp+ ports and 1gbps rj45 port, at around 150$ or less.
The cards are bad choice like someone already said. You'd need a switch with XR ports to use those cards. Luckily sfp+ cards are relatively cheap, 35$ and up...
See the Solarflare cards here : https://unixsurplus.com/adapters/?sort=priceasc
regular profile / normal profile
https://unixsurplus.com/solarflare-sfn6122f-dual-port-sfp-10gbe-pci-e-high-profile-server-adapter-card/
https://unixsurplus.com/solarflare-sfn7122f-flareon-ultra-2-port-10gbe-pcie-3-0-server-i-oadapter-0gvrr7/
https://unixsurplus.com/solarflare-sfn7022f-2-port-10gbe-sfp-pcie-3-0-server-i-oadapter-full-profile/
https://unixsurplus.com/solarflare-sfn7501-s7120-sfc9120-2-port-10gbe-sfp-pcie-3-0-server-adapter-full/
low profile (but you can probably find normal profile bracket if they don't pack one with it)
https://unixsurplus.com/solarflare-sfn7002f-dual-port-10gbe-pcie-server-adapter-low-profile/
https://unixsurplus.com/solarflare-sfn7022f-2-port-10gbe-sfp-pcie-3-0-server-i-oadapter-low-profile/
other brands
https://unixsurplus.com/silicom-pe210g2spi9ae-xr-nu/
https://unixsurplus.com/supermicro-aoc-stgn-i2s-rev-1-01-dual-port-10g-sfp-intel-82599-network-adapter-rev-1-01/
you can find those solarflare models on ebay as well and the site I link to also has ebay store, I think
https://linustechtips.com/topic/1383795-fiber-cable-question/#findComment-15066365
snip
So i need SFP+ not just SFP didn't know that. too easy i can just sell that switch back on ebay.
All those cards you listed are they compatible with freenas and truenas?
https://linustechtips.com/topic/1383795-fiber-cable-question/#findComment-15066424
The solarflare cards use common/popular intel  and broadcom "chipsets" so they should be supported.
you can just google model names and truenas / freenas and find out
ex first attempt i made https://www.truenas.com/community/resources/10-gig-networking-primer.42/
Quote
SolarFlare: Some users recommend the SFN 5162F. @jgreco notes he just got four SolarFlare SFN6122F on eBay for $28/each, with SR optics (3/2019). This is awesome for ESXi as the SolarFlare burn half the watts of the Intel X520's. We've had several confirmations that the SFN6122F works fine with FreeNAS/TrueNAS, and is currently the cheapest option on eBay (9/2021).
1st page : https://www.truenas.com/community/threads/supported-10gb-nics.25645/post-163157
Quote
Solarflare runs good for me.
# lspci -vs 03:00.0
03:00.0 Ethernet controller: Solarflare Communications SFC9020 [Solarstorm]
Subsystem: Solarflare Communications SFN6122F-R7 SFP+ Server Adapter
2nd page : https://www.truenas.com/community/threads/supported-10gb-nics.25645/page-2
Quote
I just got a Solarflare dual 10Gbit SFP+ card from eBay. Price was 70€ for a new card. The card is working just fine with FreeNAS-11.2-U7. I use it in passthrough mode in ESXI 6.7 U3. Therefore I had to install the legacy drivers from the Solarflare site. No drivers need in FreeNAS. Speed is awesome!
Solarflare S7120 Dual Port 10Gbe Low Profile SF432-1012-R3.3 SF-109041 (6TKHH)
https://linustechtips.com/topic/1383795-fiber-cable-question/#findComment-15066451
