Seeking direction about Fans
Solved by Mihle,
In general, intake at the front, outtake at the back, at the top and bottom you can choose, but I would do intake If the case has filters there, outtake if it doesn't.
Would probably put CPU AIO at the top of the case and GPU AIO at the front, as that is shorter distance if you have both.
(If you only had one radiator I would put it at the front no matter what it is for)
Featured Topics
INotPablo ·
Posted in Peripherals1 -
LT2 ·
Posted in Laptops and Pre-Built Systems8 -
7
joshfrog ·
Posted in Mobile Gaming5 -
5
1
f23948 ·
Posted in Programs, Apps and Websites3 -
1
