I have argb (3 pin) header on motherboard but rgb (4 pin) fans
Solved by Biohazard777,
13 minutes ago, M4TH1EW said:Because I don't feel like buying a new motherboard with maybe a new cpu for this problem just yet.
Maybe in about a year or so but not yet.
I would never replace the mobo if the only problem is missing CPU cooler RGB heh.
17 minutes ago, M4TH1EW said:When I tried to look for a 4 pin rgb header on my B450 motherboard, I found none.
This the manual for your mobo: https://download.gigabyte.com/FileList/Manual/mb_manual_b450-aorus-pro-wifi_1002_e_190528.pdf
In it you will find the location for the 4 pin RGB header:
