I cam across this article about audio and how it doesn't make a difference if you have an MP3 or uncompressed music and whatever. After reading it I don't quite know what to say. I would still like higher quality music just because even if I can't hear a difference.
http://people.xiph.org/~xiphmont/demo/neil-young.html
https://linustechtips.com/topic/138148-what-do-you-guys-think/
So you approve of the download size of Titanfall? That was mostly all uncompressed audio. Did they change/fix it?
I don't know I don't have or want to play Titanfall.
https://linustechtips.com/topic/138148-what-do-you-guys-think/#findComment-1835460
I've taken a bunch of tests and stuff and 100% of the time can tell a difference. For the better I may add ;)
I dont think anything higher quality then your average cd rip to mp3 320 will make a difference but i can definitely hear some digital garbage if the bitrate is less but for sample rate and bit depth i cant really tell.
https://linustechtips.com/topic/138148-what-do-you-guys-think/#findComment-1835472
I always try to find FLAC over MP3 if i can. its so much better!
Sure there is more data but 90% of the time I cant tell the difference but I guess if you have the disk space why not.
https://linustechtips.com/topic/138148-what-do-you-guys-think/#findComment-1835477
you can hear the difference up to 1000 kb ps flacs, after that, it doesnt matter that much. from experiences from me using my friends audio gear.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/138148-what-do-you-guys-think/#findComment-1835488
the basic principle of MP3 is that they cut out the frequencies that you dont hear anyway.
ofcourse there are different samples, but most MP3s are perfectly fine even lower than 320kbps ones. so 320 is perfectly fine.
but then again my knowledge is pretty limited in this area.
https://linustechtips.com/topic/138148-what-do-you-guys-think/#findComment-1835517
You need to do an ABX test if you want to hear for a difference.
Want to find parts in your budget? Logical Increments is the guide you need. | In the market for a headset? Read this thread. | If you're looking for headphones, please refer to this thread. | Stop being backhanded when offering advice.
CPU: Intel i7-3770K @ 3.5 GHz | CPU Cooler: Thermaltake Frio OCK | Motherboard: ASUS P8Z77-V LK | Memory: 16 GB Corsair Vengeance LP (DDR3-1600) | GPU: MSI Radeon HD 7870 GHz Edition x 2 (Crossfire) | Storage: 120 GB Kingston SSDNow V300 SSD, 2 TB Toshiba HDD | PSU: Corsair TX850 V2 | Case: In-Win Mana 136 (Black)
Monitor: ASUS VS248H-P | Keyboard: Corsair Vengeance K70 (Cherry MX Brown) | Mouse: Logitech G500 | Speakers: Logitech X-140 | Headphones: Philips Fidelio X1, Sony MDR-X05 | Webcam: Logitech C510
https://linustechtips.com/topic/138148-what-do-you-guys-think/#findComment-1848919
