Can I use these 3 8-pin connectors for my 3090?
Solved by jones177,
That is the best way to run the card.
Running it any other way may cause issues if you decide to have some fun.
The FTW3 uses 450 watts overclocked and each 8 pin is good for 150 watts. They can draw more but can end in a failure over time. So 150 x 3 = 450.
Then there is the PCIe slot and it is good for 75 watts.
Blastman ·
Posted in Troubleshooting0 -
IDuki ·
Posted in CPUs, Motherboards, and Memory1 -
Rixon ·
Posted in Troubleshooting1 -
5
Agall ·
Posted in Mobile Gaming2 -
2
