I dont have Isopropanol or ethanol on hand rn so I wondered if what i achueved without thise can be cnsidered "good enough"?
Also i dont really know if this is the right place to ask. Ty in advance
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/
Perhaps distilled water and Q-tips??
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046267
Yesh am gonna try. But what about it? I believe the cpu is still too dirty (screw you intel with ur complicated IHS) or is it fine to leave it like that (i am using the same kind of thermal paste again)
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046275
You can leave the edges below the surface of the IHS fine like that, or use the distilled water and Q-tips to clean the edges. You don't have any medical alcohol swaps??? They're a little low usually on isopropyl alcohol (70% isopropyl alcohol), as it's recommended to use 90% or greater for purity and less chance of minerals being left over once it dries. If you have a space microfiber towel laying around, perhaps an old one from a eyeglass case, you can use that to clean the IHS and coldplate. Just remember to not use it on anything else again until you clean it to prevent scratches, especially on optical surfaces.
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046287
Oh i sure have some micro fibers for glasses.
But we dont have 70% isopropanol and the local pharmacy will only sell it by order and if u announce it. Also i am 15 so thats a struggle too, would always need to take my parents.  So no i dont have pure enough alcohol sadly
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046307
Complicated IHS? You only have to clean the top surface… the rest is not in contact with anything so it doesn’t matter. You want to use isopropyl because it breaks down the old TIM (thermal interface material) so you can cleanly apply new TIM. That said, as long as it doesn’t have oils from your finger on it, it’s likely fine. You can mix new and old TIM without much performance change.
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046311
Don't overthink it. It's just a metal plate, you can even use a regular soap, just make sure it's properly dried.
There are many household solvent alternative, doesn't have to be IPA like WD40, kerosene or even gasolene.
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046323
So yeah, I'd use them to clean the IHS. I've done it before but it's just messy imo, especially if there is a lot to clean up. I've used paper tissues before too.
Ahh ok, that sucks and I'm sure rules/regulations in Germany are more restrictive than here in the US.
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046334
Actually germany dgaf about when or what u drink but buying stuff like those high percentage alcohol substances could mean you want to make ur vodka or whatever
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046362
2 minutes ago, rafe_28 said:
I got WD40. Is it fine? Like couldnt it resolve the board painting?
Nah, it's not that harsh at all. Yeah it will be fine. Just wipe any residue afterward.
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046377
Eyeglass cleaner.  And cotton balls because they're cheap and don't leave lint.
Also you don't really need to be worried about getting it super clean.  A bit of residue or fog or whatever on the surface won't affect performance at all.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15046689
  • 1 month later...
Linus made a video talking about alternative liquid to remove thermal paste.
https://linustechtips.com/topic/1381058-thermal-paste-cleaning/#findComment-15132911
