Unless you are gonna watercool it. Grab an aftermarket one.
if you are looking for a budget one the Msi Aftermarket is incredible considering its about the same price as a reference. But if your willing to spend a bit more the EVGAs ones are fairly popular. But tbh any of the MSi,Gigabyte,Asus or EVGA cards are very good and theres very little between them
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834698
well after market of course , cooler , more efficient , also better overclocking :)
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834702
general rule for 99% gfx crds is reference for watercooling and non reference for air with the exception of that sexy beast reference cooler on the 700series :P
also @Prokart2000 anyone from msi, asus,evga or gigabyte. go for whichever one you like or thinks looks best. personally i would have gone for the kingpin eiditon coz its beast but i went for reference since i plan on watercooling. good luck :)
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834721
msi or gigabyte cant choose :P
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834731
Would watercooling be a possible upgrade after? I would get a reference one cause I really love the stock cooler but a aftermarket one will only be better by a bit. The quietest cooler is a 780 + a waterblock, but when talking about aftermarket ones I have no clue.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834739
msi lightning if it goes in your build otherwise the windforce is an amazing cooler too. you wont be disappointing with either.
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834742
not watercooling on AIO h100i
My Setup :P
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834743
im thinking of gigabyte (ghz) for the op clock and cooler
yea if thats what your leaning towards go fir it cuz. you wont regret it. btw if you do end up getting it, welcome to the 780ti club!! :P  ;)
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834746
here is my build plans i wont be getting it yet so i will change to haswell-e ddr4 and maxwell http://uk.pcpartpicker.com/p/3psxu
My Setup :P
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834749
if you are going for quiet then get different fans. the corsair ones perform good but can get quite loud from what everyone says.
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834757
im doing these for the looks :D just wondering if it would look good
My Setup :P
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834765
absolutely beautiful imo id you do some color coordination.  :lol:
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834774
would the gpu fit in though if its white thats why i was thinkin of reference (any decent red z87 mobos for £130?)
My Setup :P
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834781
my buddy has a 770 by evga. had to rma 3 times i think. and he only got refurbished ones.. also they were scratched and not the exact same model as the one he primarily RMAed. my gigabyte performes better in overclocking, noise and temperatures. i would not recommend evga
        wow... pretty empty here...
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834786
the windforce is mainly black do it should fit in pretty much anywhere
https://linustechtips.com/topic/138080-reference-or-aftermarket/#findComment-1834790
