Choosing a 240Hz Monitor
SaltySwan
Hello i would like to get some advice on what 240hz monitor to chose out of a bunch, I really just want to know which one is best,  just for gaming specifically.
The monitors :
-AOC C27G2ZE 27''
-Samsung 27" LC27RG50FQUXEN
-Samsung 27" C27RG54FQU
- AOC C27G2ZU/BK 27"
Is it possible to choose IPS panel instead of VA? IPS is better in pixel response therefore better motion clarity.
But if you must choose one of monitor you listed (maybe budget constraint or knowingly you really want VA), then either of these monitor is fine, just lookout for features you may need such as speaker support, connectivity etc.
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
  • 3 weeks later...
Sorry for the late response i lost hope someone would respond, well yes mostly due to budget constraints but i am willing to spend a bit more on a better monitor if it means it will serve me well.
If you have any recommendations for an IPS panel monitor that isn't too expensive i would love to hear it.
If you are strictly planning for 1080p, 27 inch and 240hz then either Viewsonic Elite XG270 or Alienware AW2720HF, both are IPS panels.
However 1440p is more preferred as sweet spot for 27 inch monitor. If you are willing to sacrifice higher refresh rate for more resolution then Gigabyte M27Q (170Hz) is probably the most bang for your buck 1440p IPS monitor.
The m27q is a great monitor. Some people don't like the sub pixel layout on it tho, it makes text look different
No cpu mobo or ram atm
2tb wd black gen 4 nvme
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Gigabyte m34wq 3440x1440
Xbox series x
