Is my PC "smart enough" to run 3200Mhz instead of 3600Mhz?
Solved by TMobile,
4 minutes ago, jwwagner25 said:what does BIOS say?
This might've fixed the "issue". Just checked and for some reason 3200 was selected in Bios instead of 3600. Was running 16gb at 2933 previously so not sure how that happened.
Currently HWinfo shows:
Assuming the difference between 1802 and 1796.1 doesn't matter.
CPU-Z:
^ still showing 3200 tho
