CPU PSU 8 + 4 Pin Extension, Asus Thor 850w CPU cable too short.
Solved by RONOTHAN##,
3 minutes ago, novaforcex said:Greetings everyone, I managed to connect my Asus Thor 850w CPU 8 + 4 pin cable through the front of my build, I have a ROG Strix Helios Case, the cable is too short to go on the back side of it. My question is, is there any 8+4 pin extension cable I can purchase to make it through the back of my case? I can only find 8 pin extensions on amazon. Any help will be really appreciated and thanks for taking the time to read me. Take care guys and stay safe.
You can find 4+4 pin cable extensions and only use the one half of it, it's the way my system is setup. I don't know if there are any dedicated 4 pin extensions out there.
