NO DOUBLE POST PLEASE!
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1825561
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1825563
SPAM!
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1825564
quaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaad
Specs
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1825566
you're going to get yourself banned if you keep this up mate, want to know why no one is offering suggestions. cause what you're asking for doesn't exist. sub $100 boards will melt under a 8350.
"I have the perfect cure for a sore throat, cut it" - alfred hitchcock
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1825571
I need a motherboard for my AMD fx 8350.I'd like to stay below $100. What is a good board?
Gigabyte UD3 990fx is like the lowest end board id go for
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1825573
You only need to post it once.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1825590
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
^ Only cheaper board I would run one with and I wouldn't push it much past low 4's. 8 + 2 power phase. Other than that? Go 990fx Gigabyte/Asus. They cost quite a bit more. Looking at 120-130 on sale. If looking at a high 4's overclock? You are looking at a Sabretooth. At that point you are better off going Intel and a z87 g-45 imo.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1825675
Asus M5A97 R2.0:
http://www.amazon.com/ASUS-M5A97-R2-0-SATA-Motherboard/dp/B008V9959O/ref=sr_1_1?ie=UTF8&qid=1397250044&sr=8-1&keywords=asus+m5a97+r2
I'm currently using one (admittedly with an FX 8320) and its great :)
Edit: a friend of mine has the same board with an FX 8350, still great
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1846837
This.
990FXA-UD3 Rev 4.0 to be exact.
1+
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1847842
Asus M5A97 R2.0:
I'm also using this board with the 8320 and I never had any problems with it. Though I don't know how well it does with overclocking.
To us were left the wonders of creation: Beasts of air, water, earth... and steel.
https://linustechtips.com/topic/137403-fx-8350-mono-help/#findComment-1851937
