WIll my graphics card be bottlenecked?
Hi all, i have posted here before, and after some playing around, I have a new PCPP list. It consists of an RTX 2060, 16 GB RAM, and an Intel core i3 10105F.
That's my problem. I'm not sure if my graphics card will be bottlenecked by my more budget CPU, and i'd quite like to keep the RTX card.
Here is the PCPP list if you want:
https://au.pcpartpicker.com/list/QPHLMv
If I would be bottlenecked, what CPU would you recommend, I know there is very much around this price range so i can pay maybe up to $100 more. (Australian dollars).
I have also made a similar PCPP list with an AMD CPU, though the specs of the 3300X and the 10105F are quite similar, so maybe i should choose a different CPU? I'd also like it to be slightly cheaper.
https://au.pcpartpicker.com/list/7KLKfP
Thanks.
