Is there such a thing as too little power draw from a PSU?
2 minutes ago, AlliedVera said:if pulling a small load can harm a PSU?
There isn't really such thing as too little a load on a PSU. Power supplies tend to do better when pulling a smaller load.
2 minutes ago, AlliedVera said:I've noticed a sort of a squeal,
It's probably coil whine, it's pretty common on cheaper power supplies. Not necessarily dangerous, but a sign that the PSU is using cheaper components that in turn might be dangerous.
3 minutes ago, AlliedVera said:but I've heard that lower tier Thermaltakes should be avoided.
Yes, at all costs. They have a tendancy to blow up, and if you're still in the return window, it's not a bad idea to return it and buy a better PSU (assuming you got a lower tier unit).
4 minutes ago, AlliedVera said:I've heard somewhere, that if you run a 2xPSU setup, you should add something on the 5V rail too
That's because, particularly for older and cheaper power supplies, they weren't designed to have their entire load given through the 12v rail and expected at least something to use 5v on the unit, and if enough wattage was drawn through the 12v rain, the PSU would blow up. Better designed PSUs don't do this, but that Thermaltake unit might not be the highest quality unit and therefore might. That being said, a dual PSU setup is basically never recommended outside of very specific circumstances, and you're much better off using one better unit rather than two meh-grade units.
