I have a "big" problem
Go to solution Solved by mariushm,
10 minutes ago, aday said:
ok ill try that thanks
Windows key + pause/break to open settings in Windows 10, then on the right click on Advanced System Settings, then advanced, Performance > Settings , Advanced, Change ... make sure there's page file configured on both drives.
Windows will prefer the one on your SSD and if that gets full, goes to the mechanical drive.
You can manually limit each page file by setting both min and max values to same value.
For your system with 8 GB of ram, you probably want at least 24 GB of page file in total.
Should add a second stick when you can, it helps.
BUT  open the pc first to see if you have one stick or two sticks of ram already, and if there's an empty slot to add memory.
If you have a single stick of ram, adding a second stick will make the memory work in dual channel mode which gives a performance increase just by the simple fact of having two sticks, and then you have an extra performance increase on top of that from the extra capacity (ram amount).
Soo, I'm 14 had a job over the summer to pay for a new pc. I bought this pc less than a month ago, and no I did not build one because of gpu prices. It is a hoP pavilion prebuilt with a i3 10100 1650 super and 8gb of ram. For storage i have a 250 gb intel optane m.2 ssd and a 1tb western digital blue. My problem is that as soon as I got the pc, I realized that my temps are normal for a prebuilt, but the gpu and cpu usage is extremely low. For example in Rust, a gpu intensive game, I get about 50% of both gpu and cpu usage and this is even on the highest settings possible. On Call of Duty Warzone, i get around 70% of both in game. In games like Minecraft im getting about 20% gpu and about 10%cpu usage. I have tried everything I can think of and watched way to many youtube videos and read way to many forms. I did a full reset of my gpu drivers using ddu, ive checked bios for anything, but did not see much because the bios is limited. I have even changed everything to high performance in nvidia control panel. pls someone help me this is starting to piss me off. Keep in mind even when games are maxed, expect warzone cuz that is way to much vram.
https://linustechtips.com/topic/1371066-i-have-a-big-problem/
You're probably limited by the 8GB of RAM. Most of those games (besides Minecraft) use a ton of RAM. CoD for example has 16GB as the minimum amount. There is a decent chance that you are using the pagefile a ton, limiting what your CPU can do, and thus limiting what your GPU can do.
Minecraft is probably just Minecraft being Minecraft. it has issues with utilization unless you run it with optifine. With my 3080 for example the card doesn't even clock up when running it unless you're using shaders, sticking to 300MHz half the time.
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974111
what do you mean by pagefile im a little slow
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974123
You said, you have a big problem. What's the big problem?
Don't you get enough FPS?
If you get 60 FPS and the games are maxed out, I don't see a problem.
If you want more FPS, 16 GB RAM could help.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974124
If you open up taskmanager, then in performance tab/CPU right click the graph and hover over "Change graph to" and then click on "Logical Processors".
See if you can see if a single core (or several) are at 100%.
If that is the case the per-core speed is holding you back.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974127
no no no my utilization of my gpu and cpu are extremely low no matter how high the settings are.
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974128
i tried that and none of them were at 100%
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974133
The system is starting to use the SSD/Hard drive as if they were RAM. Since you have Optane, it's not the worst thing that can happen, but I've seen it where the page file defaults to the hard drive for some reason. You can check the page-file usage in Windows somehow, I forget how and am too tired to look it up, but if you just Google it you should be able to figure it out.
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974141
Do you have V-sync turned on? (if yes turn it off and see).
I was gonna ask if you have a frame-limiter set, but not many games have those.
Also make sure its not using the iGPU of your i3 when you're gaming.
Not having an iGPU, i dont know where to set it up sorry.
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974143
ive done all of that aswell and i always check what gpu it is using and it is never integrated graphics.
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974145
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974149
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974176
cmon man its a hp prebuilt its single channel lol but i had to open the pc to put in a hdd and ill put that amount thanks
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974183
it worked thank you so much!!!!!
https://linustechtips.com/topic/1371066-i-have-a-big-problem/#findComment-14974199
