Does Pentium 4 have a thermal sensor?
Solved by Jurrunio,
It has thermal throttling capability but I dont think it produces any reading. If there is one it will be read through the super I/O chip on the motherboard. I dont know if this motherboard uses one with software support but sounds like the motherboard reading you're getting is as good as it will be
Seosamh_101 ·
Posted in Windows0 -
1
1
2
3
ShayOh ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
