How would I uninstall a Bash Shell script?
Go to solution Solved by Guest,
It has a built in function to remove the packages
download https://github.com/piscripts/pijarr/blob/master/pijarr-setup.sh
Change
main() {
    clear
    term_colors
    script_info
    check_superuser
    check_continue
    pkg_update
    pkg_upgrade
    pkg_cleanup
    setup_dependencies
    #remove_app jackett sonarr lidarr radarr
    setup_app jackett sonarr lidarr radarr
    remove_temp
    final_info
to
main() {
    clear
    term_colors
    script_info
    check_superuser
    check_continue
    #pkg_update
    #pkg_upgrade
    #pkg_cleanup
    #setup_dependencies
    #setup_app jackett sonarr lidarr radarr
    #remove_temp
    #final_info
then run it.
I installed this https://github.com/piscripts/pijarr, it's "a bash shell script to automate the setup and configuration of JackettSonarrRadarr, and Lidarr on a Raspberry Pi."
Which works great, and I only wanted to test out if radarr/sonarr was good for me, turns out I dont really need it.
So I want to uninstall all 4 of those, how would I do that?
It installed some extra stuff, but I can probably remove unnesessary stuff with apt. I have access to ssh and vnc, those apps arent shown in the gui as they are added via script.
I do have a backup point set before I installed that script, so I can just go back to it, but I wanna know how to uninstall anyway.
Thanks.
https://linustechtips.com/topic/1368791-how-would-i-uninstall-a-bash-shell-script/
Try the following commands one at a time and see if you see anything related to uninstall in the results...
ls /usr/bin | grep pijarr
ls /usr/local/bin | grep pijarr
ls usr/sbin | grep pijarr
...if the script left an uninstaller it should be in one of these 3 directories otherwise its just a case of manually removing everything you don't want. Remember you really don't need to worry about orphan dependency libraries, having them installed won't affect the system in any way.
Main Rig:-
Server:-
Maybe you can try uncomment that and remove the line below it. Run the script again.
Change
main() {
    clear
    term_colors
    script_info
    check_superuser
    check_continue
    pkg_update
    pkg_upgrade
    pkg_cleanup
    setup_dependencies
    remove_temp
    final_info
to
main() {
    clear
    term_colors
    script_info
    check_superuser
    check_continue
    #pkg_update
    #pkg_upgrade
    #pkg_cleanup
    #setup_dependencies
    #remove_temp
    #final_info
then run it.
