Build feedback $3000 system
4 hours ago, Malevevely said:
Power Supply ASUS ROG Strix 750 Fully Modular 80 Plus Gold 750W ATX Power Supply with 0dB Axial Tech Fan and 10 Year Warranty (Model:ROG-STRIX-750G) 189.99 7% CPU AMD Ryzen 7 5800X Vermeer 8-Core 3.8 GHz Socket AM4 105W 100-100000063WOF Desktop Processor (Model:100-100000063WOF) 499.99 17% GPU ASUS ROG STRIX GeForce RTX 3080 10GB GDDR6X PCI Express 4.0 x16 ATX Video Card ROG-STRIX-RTX3080-O10G-WHITE-V2 1499.99 52% Motherboard MSI MAG B550 TOMAHAWK AM4 AMD B550 SATA 6Gb/s ATX AMD Motherboard 189 6% Storage SAMSUNG 980 PRO M.2 2280 500GB PCI-Express Gen 4.0 x4, NVMe 1.3c Samsung V-NAND Internal Solid State Drive (SSD) MZ-V8P500B/AM 139.99 5% Case LIAN LI LANCOOL II MESH RGB WHITE Tempered Glass ATX Case - White Color - LANCOOL II MESH RGB-W 139.99 5% RAM Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 16GB (8GBx2) CL16 BL2K8G32C16U4B (BLACK) 116.99 4% Cooler Cooler Master MasterAir MA624 Stealth CPU Air Cooler, 6 Heat Pipes, Nickel Plated Base, Dual Tower Aluminum Black Fins, Push-Pull, Dual SickleFlow 140mm Fans for AMD Ryzen/Intel 1200/1151 131.99 5% 2907.93 1
The PSU is not great, there can be more affordable models had with more wattage. That also perform great. Like the Corsair RM850x.
The CPU is okay, but for purely gaming I'd also go 5600X. At your budget the 5900X seems more sensible. So why not go for that?
Damn that GPU price is hefty... over 50% of your budget spend on not even the most high end graphics card available. I'd go for the 3080TI in a non white enclosure.
The motherboard is fine, I think you can save a few bucks there.
Case and storage are a good choice, I'd choose something similar.
For ram, go with at least 3600MHz. Ryzen runs faster with faster memory, so 3600MHz is the sweet spot of price and performance.
For that price, you can get an AIO, like the liquid freezer, that will run cooler and better. If you want white, corsair has a few white AIO's.
