PC Case For Custom Loop Build.
Go to solution Solved by Ravendarat,
I have the 7000 currently sitting here waiting for parts but after watching videos and going through it I think its gonna be a monster in the watercooling community, its just so well outfitted. The Fractal Torrent would NOT be my choice as its layout is actually kinda shit for water cooling unless you are gonna ditch the 180mm fans, in which case why even spend the money on that case
So I am thinking of doing a custom loop, and I am considering the 7000x, Antec P120, Fractal Design Torrent, and maybe the Thermaltake View 71.
Is there a more premium case similar in design to the Antec P120, with a lot of glass, because I want to show off the custom loop.
https://linustechtips.com/topic/1367582-pc-case-for-custom-loop-build/
O11d since its basically the go to for watercooling
Are you doing your watercooling for asthetics only or do you care about overclocking and/or extreme silence?
If its only a pure asthetics thing then dont bother, you are only harnessing all the downsides without any of the benifits
performance, aesthetics, and silence, maybe some overclocking. I dont really like the way the O11 looks
In this case watercooling is justifiable since you want some extra cooling, silence, and ocing
Tbh idk what case i can reccomend then, maybe an enthoo pro (2)? Since its pretty large and also alot of radiator space
not cheap but here
https://www.amazon.ca/dp/B08PPSKP3J/?coliid=I3V6KD2HE6IZ6C&colid=1FAOHYDQQPCKN&psc=0&ref_=lv_ov_lig_dp_it
Phanteks Evolv X. I was between this and the O11 and sometimes wish I'd gone for the Evolv.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
