need a watt meter
Go to solution Solved by Guest,
19 minutes ago, gloege said:
well will keep looking into it still open for suggestions. the one suggested 149 usd  seems no more efficient then a cheaper one under 50 usd
Efficient?  I think you mean accurate.
Thing is, you can trust the Brand's numbers.  I've had devices like the Kill-A-Watt, Belkin power meter, etc. tell me that I'm drawing less from the wall then I'm actually using (eg:  AC reading was lower than DC load).  The Brand never did that to me.
Anything commercial for around 15-30$ will have a reasonable accuracy ... give or take 1-2 watts.
It's good enough.
If you want more accurate, you get a clampmeter and you make a custom AC cable so that you can clamp over the live wire and log the current and then separate measure the voltage with another multimeter.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946863
It's good enough.
i did trip over google and saw one that plugged in the wall but did not have a detachable head and it was .1 watt accuracy
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946870
Yeah, but some only get that accurate within some range like let's say from 50w to 500w.
I'd say below around 50w, assume it's +- 1w.
Some won't be able to accurately measure less than 1-2 watts, so don't use them to measure how much your phone charger consumes without anything plugged in, for example, because the 0.1w or whatever the charger consumes idling is below the meter's capabilities.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946873
I wouldn't believe that number if its me.
If you want truly accurate devices you paying much more. Id just get a cheap one, there all ok for accuracy.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946877
yea it stated to the nearest watt it was .1 watt accurate
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946880
1 minute ago, ShrimpBrime said:
Just get a P3 Kill-a-watt from harbor freight. I think they are about 25 bucks. Probably find em cheaper online.
i heard it not as accurate. just wish mine was not stolen. now i might have to buy an extension cord to go with it. really looking for one with a detatchable head
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946886
None of these are super accurate and calibrated. I wouldn't look at their specs much as there probably wrong.
Why not just buy the same one with the cord?
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946888
That's where I got mine!!! Used a 20% coupon (wish they brought them back...now they got stingy) and brought it down to ~$20 or so.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946900
Haha yeah, stingy bastards.
I grabbed a power inverter from Wal-Mart last year. 1500w has a wattmeter built in. Had to run that off my car overnight when we lost power from a storm.
A few years earlier my generator died.
Tell you what, idling the car all night with the inverter was the quietest way to run my fridge and living room, I'll never buy a generator again. With the fridge, TV, htpc, and some lights was able to average 450w on load with the fridge running. Fridge start up was peaking 800w though. The inverter was about 110 bucks vs 3500 bucks for a generator. I've changed the way I make power in recent years. Ran it off 2 point slow jetta motor. In 15 hours used maybe 2 gallons of fuel.
Old kill a watt confirmed the power draws. Within 1 to 2 watts, the extension cord 30a is 100 foot long, so probably loose a little there.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946935
Yeah, generators can be pretty expensive and a lot of people don't maintain them after using them after the power goes out. They don't check it to ensure it's ready until the last second. I had an opportunity to get a power inverter once for my car from a neighbor's garage sale, but I never purchased it. I don't believe it was as high of a wattage as yours though, for $5.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14946968
Oh mine was just old as the hills. Was my grandfather's. Ran great. The regulator blew up. It turned fine but was only producing sporadic low volts.
I'm telling you though, couldn't hear the car running outside. Super quiet electricity production. Find an inverter for cheap, snag it up!!
I plan to get a "refurbished" deep cycle and use this in case of emergencies instead of running it off the car. Maybe a couple few batteries. Attached garage, both fridges are like 15 feet apart at the new place.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14947001
That sucks. Yeah, its a cheap way to produce electricity. I'm sure it probably costs less in gas to run that instead of a generator too (depending on the car and engine size).
That's not bad at all. Always be prepared.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14947018
I've lost food from power outages and not being prepared for it. Last time almost caught with my pants down. Thought of the inverter idea, I bought the nicest one they had on the shelf.
The wattmeter on it is nice.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14947025
At my surveying internship, the crew I was with had to buy a converter (EverStart) at Walmart once as they forgot to put the batteries for the data collector on charge. We had to take a quick detour to Walmart so that by the time we got to the job, we had some juice in the batteries. No problems whatsoever, so they seem to hold up.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14947034
i have no combustion engine and only need a plug in one that does not invert
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14947044
I've only used it once heavily like that. So longevity of pounding I can't say.
So used
Htpc is 2700x and 2060. B450-I gaming.
During gaming, I watched the meter. It maybe spiked 40-50w with Beam N G Drive with AI on and heavy loads. But most of the time the PC pulled about 85w on average. The fridge working power was below 350w and the lamp was like 6w leds. Spikes over 650w-750w startup.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14947046
Yes, I'm sorry. Have derailed a little bit. Those posts where for the Spiderman.
But you can get a lot of stuff with a wattmeter built in. I guess I wanted to show that thought.
My apologies.
https://linustechtips.com/topic/1367214-need-a-watt-meter/#findComment-14947051
