hi, is there some kind of tool or recommended website that can provide a GOOD, if not accurate, measure of what wattage of psu i should be getting.
i know there are several websites, but they all gave me quite different answers, so that's why i'm asking if anybody here has solid recommended website or tool.
thanks.
https://linustechtips.com/topic/1367117-power-usage-estimate/
thanks.
I've always used Seasonic wattage calculator. So far i've found it nearly accurate. The website though seems to have been changed now and doesn't work anymore for me. So i use the bequiet! one
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946095
I'd use the Seasonic one, and then add a fair bit for safety. It also largely depends on overclocking, etc, something you need to look into and estimate yourself.
You shouldn't buy a PSU that barely meets your systems needs.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946110
it just told me to get a 1300w psu..... holy crap, i didn't know i would need a 1300w......
8700k + two msi gtx 1080ti + one ssd + two 7200-rpm hhd
1300w?? really??
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946112
1300w?? really??
What it tells you to get and what your system actually draws differs. What does it show your system wattage as?
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946123
Two 1080Ti's on an 8700k? I wouldn't do anything below 850w, that's for sure.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946129
3 minutes ago, Error 504 said:
sorry, am i missing the number somewhere?
i don't see the estimated wattage......
This is the issue in the website I was talking about. Which is why i recommended the bequiet one. Both were about the same give or take some.
image.thumb.png.be19ea0e819fd292196b39cdf543c2a7.pngThis is what the bequiet one suggests, so i'd get a 850W PSU at the least given you haven't OCed your parts heavily.
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946138
ah thank you so much!
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946144
1300w?? really??
1300w because it's a Seasonic. Some models fail with high-end GPUs. A 1300w Seasonic is needed where you can run it with a 850 - 1000w Corsair.
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946227
it recommends a 1000w psu, but 850w should be sufficient. how much headroom do people usually leave regarding power supply? as bequiet puts it, what's a healthy % of " load " ?
thanks.
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946270
thanks.
If you have, say, a 760W estimate, then I would go with a 850W, I generally look for atleast 100-150W of headroom. Also for future-proofing a bit. Tho If you can snag a 1000W one, you'll be safe and happy for the next few years of upgrades
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14946272
just out of curiosity, what devices or peripherals can 100w - 150w accommodate? few extra fans? extra aio cooler? extra storage? extreme oc?
thanks.
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14947450
thanks.
Yeah maybe a few fans and a couple or hdds more, with a bit of oc on the cpu or gpu. Not much, but that's headroom so that if your gpu or cpu spikes up in power draw, it doesn't crash your pc
https://linustechtips.com/topic/1367117-power-usage-estimate/#findComment-14947555
