And what exactly is getting harder and harder? If your ISP doesnt use CGNAT (which is very rare nowadays) and allows you to open ports, all you gotta do is set a static IP to your NAS (either by setting up on the NAS or by assigning a static dhcp on your router), make sure your forwarded ports are actually open, you can either manually update your Public IP of your DDNS or run a client to update it automatically.
https://linustechtips.com/topic/1367016-trouble-with-ddns/#findComment-14945428
Basically I want to map that nas drive onto my windows file explorer outside of it’s local network. And idk how to do that
https://linustechtips.com/topic/1367016-trouble-with-ddns/#findComment-14945450
Create a VPN server on the NAS, connect to it from your remote client and map in the exact same way as you would locally. You really shouldn't be forwarding SMB or NFS shares to the internet.
Main Rig:-
Server:-
https://linustechtips.com/topic/1367016-trouble-with-ddns/#findComment-14945462
