Will it fit
Liammore
Hi so I’m having a debate weather my mother bored will fit in a case so I have the MSI B450m pro M2 max it has dimensions of 24.4x20.6 cm I want a little case so it would fit on my desk and found the cooler master NR200 it is an ITX case but it said “compatible with mini-ITX and DTX. the psu can be front mounted for extra motherboard clearance with a maximum size of 24.4x22.6cm” my question is would my micro atx motherboard (with the dimensions above) fit into this case. And if not can you suggest any small cases that it would fit in. To me it would fit but I thought I should get a second opinion
really sorry about the grammar i struggle with it I try my best but it always fails.
thanks
39 minutes ago, Liammore said:
MSI B450 m2 pro max it has dimensions of 24.4x20.6 cm
If you front mount the PSU, the NR 200 supports mainboards up to 244 mm length and 226 mm height.
(MasterBox NR200 Mini-ITX PC Case | Cooler Master)
The mainboards dimension are 9.6 in. x 8.1 in. (24.4 cm x 20.6 cm), but if you look at a picture, you see that the mainboard has more height than width. So it actually has 244 mm height and 206 mm width. So it doesn't fit into the case.
Very confusing, but if you look at the pictures of the mainboard, it makes sense.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
Jonsbo V9 Micro-ATX
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
It is a bit confusing and I don’t really get it to me because me my motherboard will fit in as it is under the limit.
can you just explain it again thanks
sorry
The space for your motherboard in the case is 244 mm from left to right and 226 mm from top to bottom. But your motherboard is 244 mm from top to bottom and 206 mm from left to right.
So it would fit, if you turn it 90°, but then the I/O wouldn't fit.
The mainboard is too high for the case.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
Oh crap. That would not work 🤣 thanks for your help
2 hours ago, suedseefrucht said:
Jonsbo V9 Micro-ATX
would you happen to know something small but a bit more budget friendly
Fractal Design Focus G Mini
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
Thanks
