So ussually in games my CPU temp is about 67-70'C.
CPU is Ryzen 5 3600
Today when i was playing NFS Heat i noticed it was 71'C and then it spiked quickly from 71'C to 81'C and then immediately it dropped from 81'C to 71'C.
Is this normal ? I checked again a few times and it was still 71'C while playing but what about that spike ?
Also how do i know if it stayed continuously like 10-15 minutes at 81'C all the time or if that was just a spike ?
Any way i could find out if there were multiple spikes ?
I would greatly appreciate if anyone could shed some light on this.
https://linustechtips.com/topic/1362871-ryzen-5-3600-temperature-normal/
What cooler is it?
If it's stock cooler then it's "normal" and totally fine
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
1 minute ago, Mikey89 said:
@Freakwise
I'm using a BE QUIET! Shadow Rock LP
It was some what expected really, and I'd say it's perfectly fine
Iirc you could use hwinfo to make a log of cpu temps, though don't ask me on the specific
Sorry i'm not exactly an expert, but what do you mean ?
Some adițional info maybe it helps : the cooler is 5 years old, i've had it before in my FX 8300
Oh sorry, I'm little bit misread your post
What i mean was those temperature is fine considering youre using shadow rock lp as a cooler and temperature spike is normal thing
And like i said in my previous post you can log cpu temps using hwinfo
19 minutes ago, CallumOKane said:
How much CPU is being utilized while gaming, and is it just the games utilising it? You can monitor this via task manager.
@CallumOKane
I have no idea, how much should my CPU be utilized while gaming ?
I did notice though that CPU fan when gaming is at 100% - not sure if this helps or not.
first of all: what's your ambient temperature?
that spiking is normal, as the die is slightly off center, those spikes usually happen when a core closer to the edge of the cooler is stressed.
about the temp: 81c is a lil high, but nothing to worry about.
given that you are using that Shadow Rock LP those temps are absolutely where i would expect them
about HWinfo:
you just start the program, and it will give you "current" "min" "max" and "average" temps.
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
@Freakwise
Is BE QUIET! Shadow Rock LP a bad CPU cooler ?
Also how much should my CPU be utilized while gaming ?
Sorry for asking but i literally have no idea.
I did notice though that CPU fan is at 100% when gaming - not sure if this info helps or not.
Well not it's not necessarily a bad cooler, i mean it keeps your cpu temps under 90c under load
Its hard to answer as i didn't know how much "X" cpu will get utilized on "X" games, so yeah, it's pretty hard for me to answer although my rule of thumb is that it shouldn't be below 40 to 50%
@Freakwise
It's not a bad cooler, it's just not a high performance cooler. Its advantage is that it's a low profile cooler. If you can fit a bigger cooler, it's probably going to be a better option (I wouldn't bother though, your temps aren't that bad).
Ideally it should be 100% CPU and 100% GPU, however that's very rare. It really depends on the game. Doom Eternal I'd expect somewhere around 30-40% total CPU, while Civilization VI I'd expect closer to 80-90% (numbers will be a bit off).
100% CPU fan usually means the cooling isn't quite adequate. It might just be the thermal paste application isn't great, so that would be what I consider first before getting a new cooler. Case airflow might be another area to look at, if all your filters are clogged that can be causing higher than idea temps.
@RONOTHAN##
PC case is Cooler Master Masterbox MB511 RGB and i have 6 fans on it :
- 3 front intake
- 2 top exhaust
- 1 rear exhaust
This is the first time i ever saw a spike.
Will i damage my CPU If i continue to use my current cooler ?
Also CPU is 1 month old.
If it only went to 81, you're fine. If it goes above 90C, that's when you have a problem. You might be losing out on some performance with higher temperatures, but it's not that big a deal. The stock cooler keeps it at roughly these temperatures, so the CPU is definitely fine running at them for its rated lifespan.
- 3 front intake
- 2 top exhaust
- 1 rear exhaust
That should be a pretty good cooling setup, that case isn't that choked for airflow.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Well that's what i thought as well regarding nu case and cooling.
But does that mean the CPU cooler is struggling even with said case and cooling ?
Should i look into getting a new CPU cooler ? If yes can you recommend some good ones ?
4 minutes ago, Dedayog said:
Thanks, that will surely help now... LOL
I know that thread will makes it seem like i'm paranoid guys but believe i'm only asking cuz i'm concerned about my CPU.
Go 360mm AIO or Dark Rock Pro 4 or Noctua NH-D15.
OnePlus Ecosystem:
3D Printing:
I'd only bother looking into getting a new cooler if it becomes a problem for you. If you want the extra performance and extra peace of mind that your components are better cooled, the Hyper 212 is a great cooler for a cheap price. If you want the best you can get, go with what @Dedayog suggested and get an AIO or one of Noctua's bigger coolers. However, the biggest cooler you will probably need to go is a Noctua NH-U12S, but even that will be overkill for your CPU.
Isn't that bit overkill for 3600?
@RONOTHAN##
Well regarding performance, the CPU wasn't underperforming i'd say... i mean i was getting really good 100FPS with no drops and on max settings.
I'm just concerned, will i damage my CPU If i continue using my current Shadow Rock LP ?
Will Noctua NH-D15 or BE QUIET! Dark Rock Pro 4 even fit inside my case ?
They seem really big what i saw when i googled them.
It might be tight, but looking at the official dimensions they will fit (just barely). However, you don't need that big of a cooler for a 3600.
@RONOTHAN##
My CPU wasn't underperforming, i was actually getting 100FPS with max settings.
Will i damage my CPU though If i continue using my current Shadow Rock LP ?
I'd rather stick with my current cooler i think.
Guest
