Is a cooler master i30 enough for an i5 7500?
Solved by DeadlyDivs_,
20 hours ago, WoodenMarker said:60c isn't low but not dangerous. What are load temps?
So i decided to go for the i30 just to see if it would work fine and it did!, in valorant it has a max temp of 60C while in COD Modern Warfare 2019 i have a max temp of 75C and it is also pretty quiet so i guess ill stick to this for now but i will probably buy a better processor in the near future, if u are still curious about what my temps were before using the i3 7100 stock cooler, it was always at 100C in most of my games, so it was always thermal throttling. anyways thanks for all your help
