Strange 780 problem
Go to solution Solved by James199001,
problem sorted, im so happy right now that i dont have to rma my card. I downloaded the previous drivesr for my card and did a clean install with them, played red faction guerila because it seems to happen most on that game and dead island riptide, it didnt have a problem.
There must have been a conflict between the newest nvidia drivers and others on my pc.
Thanks for all your help anyway people.
now how do i delete this thread or does a mod do it?
Heres my problem,
I got the 780 new about 1-2 months ago, about 2 weeks ago i noticed that whilst gaming the screen would disconect briefly (like 2 seconds) every 1-2 hours.
I ignored the problem as i thought it may just be a glitch of some kind but in the last 3 days it has started doing it every 1 to 10 mins whilst gaming, it also does it whilst not gaming, it did it twice whilst writing this already.
Firstly i blamed it on my monitor, because i have a 2 monitor setup and only the primary monitor would have the problem but after swaping them around it is still the primary monitor that suffers no matter what monitor i use.
I have already tried different ports on the 780 so im sure it isnt a bad dvi conection problem.
I have tried using another PCI slot on my asus sabertooth z87 but the problem is still there so it isnt a pci problem.
The power supply i am using is a ocz zs 750W 80+ bronze so im sure its not that.
The graphics card never reaches over 70c
I tried a clean install of graphics drivers too but no luck
Because of all of this I would say it is a bad chip or bad solder on the chip but would like somebody elses idea on what it could be, I dont want to rma it and find that its not the gpu thats the problem.
all my specs are here, all parts are about 1-2 months old except from the hard drive and ssd there about 20 months old, the psu is just under 12 months old
CPU: I5-4670K (Quad core @ 3.4hz)
Graphics: EVGA Geforce GTX 780 Superclocked
RAM: 8GB (2X4GB) Kingston HyperX Beast @ 1600Mhz
Motherboard: ASUS Sabertooth Z87
Power supply: OCZ ZS series 750W
Storage: 60GB Kingston SSD & 1TB Hitachi HDD
Monitors: 27" BENQ GW2760 & 23" DGM L-2362WD
Operating System: Windows 7 Home Premium 64-bit
Case: NZXT Phantom 530
James
post-61251-0-79790300-1396729256_thumb.j
https://linustechtips.com/topic/135984-strange-780-problem/
Unrelated, but I couldn't help but notice your rear fan is pulling in air. Do you have ANY exhaust?
https://linustechtips.com/topic/135984-strange-780-problem/#findComment-1808209
I was planing on putting in A h100 I and herd it would be good that way
So you have zero active exhaust then?
https://linustechtips.com/topic/135984-strange-780-problem/#findComment-1808225
2 120 exhaust fans on the top
Ok, you worried me for a second.
https://linustechtips.com/topic/135984-strange-780-problem/#findComment-1808239
you dont need active exhaust
its better without because you can get a greater positive air pressure
thats why most people put the rear fan as an intake, because the top fans/rad is usually exhaust
if you have intake, the air gets pushed out automatically with no need of exhaust fans
https://linustechtips.com/topic/135984-strange-780-problem/#findComment-1808246
I'm not even going to bother arguing this because it's one that will never be settled.
https://linustechtips.com/topic/135984-strange-780-problem/#findComment-1808259
https://linustechtips.com/topic/135984-strange-780-problem/#findComment-1808647
threads just stay up forever
the point of a forum is so that people can search for solutions to their problems in LTT or google
and then they can find someone like you who has had the same problem, and also resolved
this thread helps others fix the same problem :)
https://linustechtips.com/topic/135984-strange-780-problem/#findComment-1809313
You should however mark the post with the solution with the "mark as solved" button
https://linustechtips.com/topic/135984-strange-780-problem/#findComment-1811194
