Need Big Help For a $1115 Worth of A Gaming Build
Solved by Dragonzeanse,
You could always use Logical Increments. They have a tiered PC parts list for the Philippines. It's a good guide to help you get started. Change the parts as you see fit. For the Arma games, you might favor an unlocked CPU and Z87 motherboard, so that you can overclock an i5-4670K later on to get better performance. Could be useful in the future, too.
I won't give you a PCPartPicker build because they don't have a Filipino variant yet. But some parts you might want to consider:
- CPU: Intel i5-4670K (AMD FX-8350 would work if you overclock)
- CPU Cooler: Pretty much anything except the stock cooler
- Motherboard: Gigabyte GA-Z87X-D3H or MSI Z87-G55
- Video Card: GTX 770 or R9 280X; try to get EVGA, Asus, or MSI.
- Storage: 240-256 GB SSD and 2 TB hard drive (Crucial M500 and WD Green are a good combo)
- Power Supply: 600-750w, rated 80+ Bronze; try Seasonic, Corsair, XFX, Silverstone, or Antec.
- Case: BitFenix Shinobi, Corsair 300R, or NZXT Tempest 410
Rest is up to you.
