Monitor Arms for 3 Monitors
Inversion
Hi, I'm thinking of getting myself a new 27 inch 1440p monitor but I'd like to keep using my 2 23 inch ones as well. I don't have space to have them all side by side so I'm wondering if there are monitor arms that could take 3 with the 27 inch on the left and the other 2 stacked to the right hand side. Does this exist? Or would it be easier to get a single arm for the new monitor and just get a single thing to stack the other 2?
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
Depends on which monitors have vesa mounts and what size.
There are some options available out there but all of them are made by some no-name companies, so no guarantee they will be high quality or any good at all.. I guess there is only one way to find out. However, they do exist. Here are some pics for example:649144.jpg
orig
I am not a native English speaker, so I might make some mistakes here and there. I am sorry in advance for that. I do my best to write as good and clean as I can. Cheers!
There are some different options to do this.  For a setup with 2 monitors below and the 3rd top monitor centered, there's the "pyramid" style triple mount.  These have been around for a long time and can be found pretty easily.
For an L-shape setup with 2 monitors side by side and the third one directly above one of the other two, the easiest method would be to get a quad monitor mount and remove the unused arm.
It's also possible to order separate arms, poles and other parts from many of the manufacturers to create your own custom mount.
Basically you’ve got to have a vesa mount to attach to an arm in most cases, and you haven’t said whether the monitors even have vesa mounts or not so it’s hard to say.  There are several suggestions here but both simply assume you have them.  There are two vesa mount sizes I know of though many that accept the large also accept the smaller.
basically this is near useless unless we know what sort of mounts you have.  The information needed is monitor weight (because some arms have weight limits) VESA yes/no. And if yes what size.  Things get a lot more complicated if no and sometimes mean no arm mount at all.  Though that can vary.  Two ways to do that one:  mount it like a crt and simply leave the stand on it, or do some weird non vesa action which only sometimes is even possible.
Edited by Bombastinator
It is all Vesa Mounts. I've linked the monitors below.
https://www.amazon.co.uk/dp/B08L6XR935/?coliid=I19AVDJM6SGSNC&colid=2DV407RFAE67J&psc=1&ref_=lv_ov_lig_dp_it
https://eu.aoc.com/en/monitors/i2369vm/support
I'm thinking it might just be easier to get one thing to stack the two smaller monitors and a second single monitor arm for the 27 inch.
If you’ve got vesa on everything there’s a bajillion ways to do it.  Pick what you want.  One other thought with vesa arms is how it attaches to the building or furniture you’re attaching to.  lot of options there too.
Highly suggest just biting the bullet and buying three separate monitor arms.
The dual-monitor arm i got does not work well with the shapes of new monitors, single monitor arms avoid all the issues forever.
The amazonbasics single monitor arm thats like $110 works great for my 34" ultrawide, going to buy a second one for my side 27" soon
System Specs: AMD 5950x PBO-AutoNoctua DH-15 Black | Gigabyte x570 MasterEVGA 3080FTW3 Ultra | (2x16gb) G.Skill Royal 3600mhz CL18 | Corsair 5000D Airflow (Black) Samsung 980 Pro 2TB & Firecuda 520 1TB & Crucial MX500 2tb850W Corsair RMX | 2 Noctua A14 CPU, 6 Noctua A12x25 Intake, 3x Noctua F12 Top Exhaust, 1x Noctua A12x25 Back Exhaust
Monitors: (Main) LG Ultragear 34" 2k Ultrawide 144hz IPS '34GP83A-B' (Side) Acer Predator 27" 2k 144hz TN 'Abmiprz'
Peripherals: Corsair K100 OPX | Logitech G502 Lightspeed | Corsair Virtuoso SE | Audioengine A2+
