1 minute ago, BLT_Sharpies said:
The ones that came with the fans and the case.
Okay. My recommendation would be to make sure you're straight with the fan and put a lot of downward pressure into it. Make sure you're using a PH2 bit. You are basically cutting threads into the fan plastic, so it will take some force.
Edit: those are the correct screws.
Is this ph2?
I'm using as much force as I can lol
You could just buy some rubber vibration dampening connector thingies (not sure on the proper name) - easy to install with the advantage of some noise reduction.
If not though, be sure your screwdriver is an appropriate size, and it can take a bit of force to screw these into fans.
Case - Phanteks Evolv X | PSU - EVGA 650w Gold Rated | Mobo - ASUS Strix x570-f | CPU - AMD r9 3900x | RAM - 32GB Corsair Dominator Platinum 3200mhz @ 3600mhz | GPU - EVGA nVidia 2080s 8GB  | OS Drive - Sabrent 256GB Rocket NVMe PCI Gen 4 | Game Drive - WD 1tb NVMe Gen 3  |  Storage - 7TB formatted
Cooled by a crap load of Noctua fans and Corsair H150i RGB Pro XT
