Low pop sound and smoke from PC, now showing RAM error light despite good ram
Solved by yeahcool946,
1 hour ago, TheEpicDuck said:It's likely that the power supply could have damaged components on the motherboard and other hardware. There isn't too much you can do other than test the components in isolation.
Well there very clearly is something that happened to something on the MB but it seems strange that turns on normally and acts like it has a RAM problem. Could it have selectively fried something that controlled the ram?
