You can change the fans most likely but probably not any other component.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1356068-cpu-cooling/#findComment-14868541
You can't switch out the rad on an AIO. It's an all in one, that's what AIO means. Pump, block, and rad is one unit.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1356068-cpu-cooling/#findComment-14868563
1 minute ago, TheLimitlessGuy said:
Look at this picture they changed out the radiator
There's no context for that image, and it doesn't mean anything on its own. That could very well just be a custom branded version of the rad. Asus does this stuff all the time. You need to be more clear about what you're asking.
https://linustechtips.com/topic/1356068-cpu-cooling/#findComment-14868706
Well it does look like there is somr custom cable mesh iver the AIO tubes (compare it to the gpu Power cable) and the ends do look somewhat handmade.
Swapping out an aio-rad is certainly possible but very hard and your gonna spill everywhere and trap even more air in the AIO
https://linustechtips.com/topic/1356068-cpu-cooling/#findComment-14869177
Why are you talking about grating different AIO's together? Just buy a loop.. they are better than an AIO.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1356068-cpu-cooling/#findComment-14869282
you can change it on some aios but not recommended. and the flue in side is secret that gives good temps and works with mix metals. you can buy expandable aios if you want.
there was a guy on you tube that did pc mods and he would replace the tubing on the aios ill try and find it.
Edited by thrasher_565
https://linustechtips.com/topic/1356068-cpu-cooling/#findComment-14871938
