i have a question about my 5950x's clock speed to see if i got unlucky or not.
so my 5950x has a maximum clock speed of 5.06GHz (since then it's gone down to a max of 5ghz not sure why probably bios updates and a unclean windows install) but only a couple cores can get to that speed with the rest varying from 4.9 to 4.72. i have seen some 5950x's get up to 5.15 and the rest of their cores being able to reach 5ghz are they extremely lucky or did i just get unlucky?
https://linustechtips.com/topic/1355629-5950x-clock-speed-question/
i've seen some1 get unlucky and cap out on 5.05/4.9 after alot of tuning even on a dark hero, but the variance is within 100mhz, 5.15 is the very top end.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
