Need help choosing GPU
Solved by Mando772004,
22 minutes ago, MechWill said:I am planning to get a 5900X but I am wondering if I should get an rtx 3080 or a radeon rx 6800-XT. Which one will pair better? Will use for rendering, playing minecraft rtx, cyberpunk rtx, and shadow of the tomb raider rtx. Will also overclock both the cpu and gpu and I am planning to use it for intensive cpu workloads that usually put it at 100% on my current 6 core cpu.
go for the 3080 you wont regret it. i also heard amd crashes in some games
